Results 1 to 10 of 11
Thread: Shop press
    Broken Bow, OK
    Shop press
    Anybody using the 20 ton or 12 ton press from harbor freight.
    Looking for some feedback... is the 12 big enough or should I spring for the 20?
    Is this brand good enough for occasional use, not complete junk?
    San Antonio/Laredo
    Thumbs up
    yeah i have use the 12 ton press before i mostly have used it to pop the barrels off and back on, on a AK, and i have used it for automotive use. have never had a problem with it. i have built 8 AK's with it already, and have used it too many times i cant remember for automotive use.
    this is the one i got
    - Harbor Freight Tools - Quality Tools at the Lowest Prices
    Broken Bow, OK
    That is the exact one I was looking at.
    San Antonio/Laredo
    Quote Originally Posted by PitchBlackC3 View Post
    lol i had the 6ton for one day, and it did not have enough power to pop the barrel off an AK. so i returned it and got that 12 ton one
    Broken Bow, OK
    I'll probably go ahead and get the bigger 20 ton one. Future proof it. I will mainly use it for u-joints, bearings, ball joints a-arm bushings and I do need something for rifles occasionally. I'm sure my dad will use it a lot and he works on tractors a lot. The bigger one might come in handy.
    San Antonio/Laredo
    yeah i would rather go for the 20 ton that day i just got that cause i want to finishes building my first ak before christmas lol
    Broken Bow, OK
    I know how that goes, sometimes you gotta work with what they have in stock.
    20 ton, pretty much will do anything youll need
    Quote Originally Posted by fubutx View Post
    yeah i have use the 12 ton press before i mostly have used it to pop the barrels off and back on, on a AK, and i have used it for automotive use. have never had a problem with it.i have built 8 AK's with it already, and have used it too many times i cant remember for automotive use.
    That is awesome. Make sure you run background checks on all the dudes buying the AK's from ya.
    Tyler, TX
    if you ever wanted to build a 40 ton they are pretty easy to construct, we have one at work that we built ourselves. It will bend a 2''x4''x12'' long steel bar. If you need a translation, it dangerous and will throw things a long long way and through cinderblock walls. but work great
    www.tjc.edu
