I need a TAC Module and Pedal Assembly for a 411 PCM. I think its just 02 and earlier Tahoes and Suburbans.
Thanks
Thanks
Little info to help your search maybe. The only trucks that have that TAC are 00-02 Tahoe/Yukon/Suburban with traction control or 01-02 Escalade and Yukon Denali with AWD. The 01 C3 and 02 Sierra Denali also have it.
The pedal is the same 01-05 and the Duramax trucks even have the same pedal. The pedal is easy to find, the TAC a little bit more of a challenge.
What are you working on that you need it?
Sorry for the late response. I bought an 02 5.3 from a tahoe and am puttin it in a 91 rcsb. Today I got a pedal from the salvage yard but couldn't find the right tac. So as long as I have the right tac module I can use any pedal from 01-05?
will the tac module outta a 99 z71 work, i have one and the pedal if it'll work for you idk
Hey I think there may be a miscommunication here. What I needed was a Throttle Actuator Control module for an electric throttle body. Not the cruise control box. Thanks for tryin to help anyway.
I bought one on eBay yesterday. The only tac module on eBay happened to be the one I needed. $80 though! I had hoped to snag one from the salvage yard cheaper than that but oh well.
Thanks for the help.
Well thanks maybe I'll feel a little better bout it
