Results 1 to 10 of 33
Thread: Turbo hot parts and intercooler
    Ft. Worth, Tx
    I am selling my Trick hot parts and intercooler setup.
    The hot parts are all stainless steel and include my driver side factory manifold, crossover set up for a 44mm wastegate vented to the atmosphere, passenger side log manifold with v-band clamp to connect to crossover, standard 3" down pipe, and a 3.5" down pipe with a built in cutout. All parts are ceramic coated. With the upgraded down pipe and ceramic coatings I have around $3700.00 in the hot parts alone. If local pick up I will also include a Magnaflow 4" stainless exhaust set up for the 3.5" down pipe.
    I am asking 2000.00 for the hot parts plus shipping.
    My intercooler is the one TRT was selling. It bolts up to the frame rails behind the bumper no modification is required to mount it up. It easily mounts with two bolts. With this intercooler I would see temps around 11* above ambient when going down the highway. This also includes polished aluminum bead rolled charge pipes set up for the trick hot parts and a factory intake manifold. The charge pipes have a flange for a Tial 50mm blow off on them and a intake temp sensor. E fans will be required for them. This also includes all couplers and T bolt clamps. I have over $1000.00 in this set up.
    I am asking $600.00 plus shipping
    I have pictures on the following link
    Turbo hot parts and intercooler - PerformanceTrucks.net Forums
    90 GMC RCSB Forged 370 and Built 4L80E from the VHO going in slowly but surely
    89 fox body notch... No motor or tranny mod but a narrowed 9" w/ 35 spline axles and a spool!!
    2011 Tundra CM 4x4...
    Feb 2009
    Quality KY.
    Intercooler air to air right. Or am I wrong and it is air to water?
    Ft. Worth, Tx
    It is air to air
    Ft. Worth, Tx
    Someone make a reasonable offer.
    Oct 2007
    weatherford,TX
    man this would be sweet in my crew cab what size turbo where u running, pm me your lowest packaged price
    [SIGPIC]5.3 k&n cai ,asm lt, hf cats, aero turbine muffler, vhp 216/224-551/551-115lsa, tbss intake, ls2 90mm tb,tb bypass, comp double roller tc, hv oil pump, ls2 injectors,nelson tune, b&m super cooler, taylor 10.4mm wires, ngk tr55ix, 373 Detroit tru trac,
    Ft. Worth, Tx
    I was running a Precision GT72Q with billet wheel.
    Ft. Worth, Tx
    Pm sent
    Oct 2007
    weatherford,TX
    ya man its a good deal damnit
    Ft. Worth, Tx
    Then come on with it. You will get the 4" Magnaflow exhaust along with it since you would be picking it up local!
    Oct 2007
    weatherford,TX
    man if u have it when i get my income tax i mite half to buy it
