Results 1 to 10 of 58
Thread: New Numbers!
    Spring, Texas
    New Numbers!
    For some reason, my truck won't ever reach full boost on the dyno. I guess it doesn't have enough of a load like on the street. Anyways, the numbers came in at:
    462rwhp/467tq @ 11psi
    Ambient temps ~ 60 with 70% humidity.
    Still got a ways to go to get to 500!!
    I'll post the dyno graph tomorrow.
    Round Rock, TX
    sweet.. where was that other thread where we were guessing?
    Spring, Texas
    Quote Originally Posted by DBRODS View Post
    Here's the thread but there are some things that are different than when I posted this. Compression is 8.4:1 NOT 9.5:1. Turbo is T-76 NOT T-70.
    http://www.ls1truck.com/forums/dynod...hp-expect.html
    The numbers kept climbing every pull we did. The first pull started out at 410rwhp!! 2nd was 431, 3rd was 45x and 4th was 462. I guess if I would have paid to keep doing more pulls I could have eventually reached 500!!
    Im pretty sure its capable of making over 500 with your current setup. Awesome numbers, I bet it runs like it has 500+
    Spring, Texas
    Quote Originally Posted by ducky View Post
    ...I bet it runs like it has 500+
    Yes it does! Especially in this cold weather! We'll see what the track says....
    Pittsburgh, PA
    thats a square power band!!!!!
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Spring, Texas
    Is that good??
    Pittsburgh, PA
    Quote Originally Posted by Sleaper View Post
    Is that good??
    yes it makes for a solid pull from idle to redline. whenever you have HP/TQ near the same numbers it usually means for one hell of a street warrior
    412 Motorsports
    Nice Numeros
    Okeechobee, Fl
    Nice numbers. Now crank that boost up and let her rip!
    49 Ford F1
