i just put on an cai and custom exhaust, how long will it take the computer to adjust to these modifications, can i do anything to speed up the process. thanks for the help.
It doesn't really need to do any major adjustments, it should be fine once fired up.
i wasnt sure, a few places i called told me to disconnect the battery for 10 minutes, thanks for the help.
nah you should be good, and now you dont have to reset any of your stereo stuff
It will work, the only thing that it could adjust would be the LTFTs. You can drain the memory voltage, but I doubt you could tell the difference.
Like PitchBlackC3 , LTFT will adjust . probably within the first tank of gas .
The computers are pretty smart , and can adjust to small add ons with no problem .
Best way is to drive it like you stole it for a few and then cruise highway for a few , then some more WOT pulls .
Now what is a tune again?
Comp Cam 54-412-11 , Int:265, 212, .522 , Exh: 271, 218, .529 , LSA 114 , Longtube , CAI (Vararam) , TransGo HD2 shift kit , tuned by me with EFILive
04 Silverado Z-71 Extended Cab
Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
06 2wd
custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
