Cleaning out the shop. I will add more stuff over the next few days.
All prices are OBO & plus shipping. Paypal only.
2006 Flex Fuel injector rail. $35
Paintable GMC body trim from C3. All pieces to fit ext cab short bed with 4 doors, or reg cab short bed and have pieces left over. $40
Left front door window regulator with motor. 2 available $25 ea.
Short overhead console light gray $18 1 left.
99-02 Passenger side window/lock switch. Gray buttons. $10
99-02 trailer brake controller install harness. OEM, can be used in 03-up by swapping pins. $7.50 each
GMRC 3.2 stereo install module. Used $20
PAC SWI-x module, new in package. $25
3 piece engine cover from my 2001 C3. Fits EGR and non-EGR. Fits 99-02 cable and DBW throttle bodies. Must be trimmed for 03-07 DBW throttle body. $100
03-07 Throttle body 78mm DBW $90
03 Intake manifold, No EGR provision, bare as seen $50:
05 DBW pedal and TAC module $60 for both:
5 wire MAF from 2004 5.3L Stock, no porting $35
NBS 3rd brake light assemblies $15, 3 available B grade (not new, not bad)
2 AC Delco outer tie rod ends for 2500HD/3500 $30 ea or $55 for pair
Delco part # 45A0834 GM # 89048972
Stock truck injectors and rails, mileage ??? $30 for both rails and 8 injectors. Crossover pipe if you want it.
[/quote]
