Hey guys, I just got my trans temp gauge installed.. My ? is, what's the normal temp that I should be running without having any problems?
Thanks guys!
Thanks guys!
06' Silverado RCSB 5.3L 4wd..
HID's Hi, Lows & Fogs
i would guess 150-165?.... i dont see a stall listed in your mods....
I do have one bud, 3k stall... Still the same temp?
I will take a gamble and say its still around the same........ whats the guage say?..
Yea ive always heard no higher than 180. the cooler the better...
49 Ford F1
Wtf! It says 240-250 at normal driving! =/
Mine runs 200-210 summer time in louisiana. In the winter, takes about 15-20 miles or more to get up to 100 if its around 30 degrees. I dont have a cooler though. Its been beat on for 140,000 miles and ran at these temps since Nov 2003, still kicking.
04 Silverado ext cab. 4.8, K&N, Pacesetter lt's, e cutout, slp loudmouths, Wheatley tune.
Normal operating temp is around 175. 195-215 is starting to get a little warm and anything over 250 is not good. If you haven't already, I would flush and change the fluid. Here's a graph to give you an idea, but IMO the cooler the better for the most part.
Transmission temperature/failure chart.
What cooler are you using?
