Page 1 of 9 1 2 3 ... LastLast
Results 1 to 10 of 81
Thread: My 403 turbo build
    Nov 2006
    Mesquite, TX
    My 403 turbo build
    eh figured i'd post some pics of the 403 build in the garage.
    Motor Specs are:
    Callies Compustar 4340 4" stroke crank
    Callies Compustar 6.125 rods
    Wiesco -20cc pistons with hardened .200 pins
    LS9 Head gaskets... .070 quenched 9 layer MLS
    243 heads milled .030 with a 5 angle valve job and a light port job and manely dual springs
    LG Motorsports G5-XB cam
    All APR 2000 rod bolts, main bolts, and head bolts
    LS2 intake
    9.6:1 Compression Ratio
    Trans specs are:
    01 4l80e
    40k trans cooler
    trans-go shift kit
    34 element sprague
    better clutches
    Fuel system:
    DBRODS fuel cell
    dual bosch 044's
    -8an feed line -6an return
    Aeromotive 13101 FPR
    80lb flow match injectors
    Aeromotive fuel rails
    Suspension:
    QA1 double adjustables all the way around
    DBRODS long bars
    DBRODS custom milled brake rotors to clear 15" rims
    Turbo specs:
    Turbo will be a precision GT 47-88
    All Trick Perf hot pipes
    Synapse 50mm WG
    4" DP
    12 x 31 x 4 intercooler
    50mm tial BOV
    I will update pics as i get stuff installed...this will be finished up over the next couple months
    Pittsburgh, PA
    that should be one sick build. im just leary on the stock heads being milled with lifting since they deck is much smaller now.. however i dont see 1 reason why this wont be a successful outcome
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Nov 2006
    Mesquite, TX
    as was i but by running the LS9 head gasket i hopefully took care of that issue... .070 vs .051 and that sticks me at a 9.6:1 CR
    Pittsburgh, PA
    Quote Originally Posted by mean05 View Post
    .7 is pretty damm thick for a gasket. you have any idea on what your quench is now?
    412 Motorsports
    Nov 2006
    Mesquite, TX
    lol that is .070 quenched...they are a 9 layer MLS gasket...badass gasket and come on the ZR-1 so you know they are designed for a lot of boost
    Pittsburgh, PA
    no no not the gasket compressed. im saying the CC quench. i know when you run a thinner then stock gasket the quench goes up and less chance of detonation. Just curious cause ive read where ppl double stack gaskets to say .8 and run into detonation issues.. thats my concern
    412 Motorsports
    Good stuff man. That motor looks awesome. Can't wait to see how the old dog likes it.
    Nov 2006
    Mesquite, TX
    Ah yeah i have no idea on that...just talked with a few diff builders and they all said i should be okay...i only plan on 18psi ish
    There you go with that word again.
    Jun 2004
    george west texas
    nice build!!!!
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
