could it be the pads...that's what i'm thinking
check the thickness of the pads if not take sum sandpaper and go over ur rotors and it'll eliminate that squeak!
2000 Yukon Xl
2003 Sierra Denali Quadrasteer
Mine do the same thing. Its time to change them but since Im lazy, I just ride them til the end of the block and they quit squeeking after they are warm.
2007 Chevy Silverado Classic 4.3L V6
Magnaflow Muffler, CFM Technologies CNC Machined High Flow Vortec Throttle Blades, STS Rear Turbo, Intercooler, Accell Distributor and Coil, 8mm wire, Autolite Platinum plugs, Runs out of fuel at 4000RPM. Marine intake with larger injectors soon. Hoping to squeeze 10psi.
Damn Jarrad, you have the 4 wheel discs too... I would look at the pads as well.
