Results 1 to 10 of 15
Thread: cognito morotorsport tie rod end kit
    Nov 2009
    anyone using these, i just got some 36 on 20's and worried about my steering. thas alot more leverage than stock tires. im already gonna buy the idler and pitman arm kit, is anyone using the tie rod end kit. its very simple idea, replaces sh!!ty ball and socket joints with heims, but still skeptical. anyone?
    Today 03:25 am 6 stringer o thats a good point, its ok ill just add a blinker fluid cooler
    Today 03:24 AMtruckinL33 that's not a good place for it, you can overheat your blinker fluid with the capacitor
    Today 03:23 AMtruckinL33 i need them for when i go back to 1985
    Today 03:23 AM6stringer i mounted my flux capacitor next to my blinker fluid resevoir
    Today 03:22 AMtruckinL33 me too, right next to my flux compasator!
    Today 03:22 AM6stringer hey gear oil needs to be cooled, i have front and rear diff coolers
    Nov 2009
    or would this be a decent alternative? it doesnt help the ball and sockets, but seems like a slightly simpler solution
    Truck Accessories | Pickup Truck Accessories & Truck Performance Parts | Stylin' Trucks
    Yea tie rod sleeves are the way to go, im about to order some since ive gone through 3 tie rods. all the diesel guys use sleeve with no problems.
    El centro, Ca.
    The actual tie rods are the weak point. One of my play grounds is Glamis Ca., and ive seen a bunch of GM IFS truck with broken tie rods. I have the idler kit, and will be installing the tie rod kit next week.
    2005 Silverado 4x4, 6" RCD lift, M/T Classic locks on BFG KM2's, 4:56 gears, Air-raid CAI, TB spacer, Nelson tuned, Corvette servos, 160 thermostat, Ebay long tube headers, Flowmaster Delta 40, Cognito Motorsports steering upgrades. 2000 Ford Lightning, 2.3 KB, bolt ons, 7.67 on the 1/8th.
    Nov 2009
    i think ur right 05, im gonna go with the full kit, the tie rods are always going out, let alone last time at the dunes i twisted a inned to just over a 90 degree angle
    thats the point of the sleeves. all the stress goes on that think sleeve and not your tie rod. No need to go spend almost 400 bucks on the heim design.
    Nov 2009
    well i guess i could always try the sleeves and see if they work out. i can always give em to a buddy if i end up going with the full kit
    If you go to the the dieselplace.com that all they run. and there doing boosted 4x4 launches .
    El centro, Ca.
    Out in the desert or dunes is different, like I said ive seen a bunch of trucks with broken tie-rods.
    El centro, Ca.
    I intalled the kit today,bought it used but in very good condition.
