Results 1 to 8 of 8
Thread: having problems shifting 2,3 gear
    Jan 2010
    rio grande city ,tx
    having problems shifting 2,3 gear at 6300rpm redline @ 6700 and shifting 2,3 at 68mph and moved the rpm to 6000 and to shift at 65mph and it shift's good i have 07 chevy nbs with a 4l65e 3800 pi single disc stock oil pan fully built tranny i want to know what's the problem
    6.0 procharged 10.9 @123
    Pittsburgh, PA
    is it not shifting at 6300? what is it doing
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jan 2010
    rio grande city ,tx
    it's not shifting
    Feb 2009
    Houston
    so it doesnt go into 3rd?
    Jan 2010
    rio grande city ,tx
    Quote Originally Posted by gTeran1 View Post
    yea
    Feb 2009
    Houston
    Quote Originally Posted by redrum View Post
    yea
    im a noob,but i would say maybe the shift solenoid?
    The 2-3 gear shifts in the 65e tend to not like really high RPM shifts cause the pump can't keep up. I would definitely add the High Output Pump Slide spring. It will allow to keep pump pressure up and hold your line pressure for the high RPM shift. Another thing you can do to help this problem is to use the Sonnax Forward/Reverse Abuse Bore Plug (It prevents fluid pressure loss and fluid bypass for the 3rd gear shift) and the Sonnax Heavy Duty 2-3 shift valve.
    Jan 2010
    rio grande city ,tx
    thanks for the help
