can a stock ls1 rotating assembly handle safely? thanks
just a tow package
I had 10 psi on my 5.3...then blew the #7 ring land. The stock 6.0 has been handling 10psi just fine. I'm not sure if David (Ducky) has a stock rotating assembly or not. I think he's @ 12 psi.
im on 9 for a little while on my stock internal 6.0
01 RCSB Race truck that is slow.....
I've been on 12 for quite a while and it's still running good. now that I put that in print, it will break.
Thanks a lot.
lol i was at 9psi with the magnacharger.
a friend of mine is runnin 13-15 psi on a stock lq4 6.0 top rpm it gets to 15 he is running a D1 procharger went 11.0 without meth.
