Results 1 to 10 of 20
Thread: Hmmm..
    Jul 2009
    Hmmm..
    Recently was changing the oil and when wiping the oil out of the skid plate, i found a broken bolt.... later to find that it had left it's home in the head holding the manifolds on. Manifold bolt randomly broke off right up against the firewall on driver side.
    Was wondering on how long it would take before it started leaking and whether to pull the motor or just pull the head??
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Racoon Twp., PA
    Honestly, they (that one) break all the time
    I had 2-3 broken for god knows how long with no leaks
    2013 CC 5.3
    81 C10 LS1 project
    ff_jeff Guest
    Just take the manifolds off, and run it like that. Open heads FTW!!!
    Augusta, Ks
    Very common. Mine was broke in the same spot. Had to weld a nut on it to get it out.
    2004 Buell XB12s
    Jul 2009
    Well from the looks of the amount of threads on the head part, it looks like it broke off past flush.
    06 2wd
    Jul 2009
    I know that acetone and trans fluid 50/50 mix is the best 'loosening fluid'....
    06 2wd
    Augusta, Ks
    mine was broke off past flush too. just get a good nut and weld in the center to the bolt. just make sure to get a good weld. The heat will help loosen it.
    2004 Buell XB12s
    Nov 2009
    chicago, il
    That's a perfect reason to get long tubes!
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    Augusta, Ks
    Quote Originally Posted by truckinL33 View Post
    Thats when I discovered mine was broken....During installation of the Lt's
    2004 Buell XB12s
    Round Rock, TX
    Done the nut trick plenty of times.. Works flawlessly...
