G3 XFI 261 HR15
COMP Cams® - Cam Details
I am thinking about using this cam in my LM7 383 build.
Anyone used this cam or have experience with it?
Thanks,
Tyler
G3 XFI 261 HR15
Thanks,
Tyler
2003 GMC K1500 ECSB running an Iron 383 Stroker ......
you could probably go a bit bigger with a 383 than that cam...you going fi or n/a?
haha. I could get a smoking deal on a new one thats why I asked.
Sorry now this is kind of overlapping on my other thread in the conversion section.
LM7 bored and stroked to 383ci (forged internals) 10:1 compression
243 heads
TBSS 90mm intake swap
Shorty headers w/ stock y pipe. (may be cut into true duals at a later date)
E-fans
so what do you think? like a Thunder Racing TR220-114?
I am wondering about the longevity of a cam like this? and the other valve train parts affected by it.
That combo will net you a pretty stout, torquey motor. Lower RPM power shouldn't be a problem, so lets see if we can figure out a cam that might not only accentuate the low end, but also scream up top.... As for longevity of the cam and valvetrain parts--it all revolves around the quality of valvetrain parts and the cam lobe design. PRC springs and the appropriate length hardened pushrods will be necessary.
I would think that a TR220-114 would be a good cam for that motor, but it would be on the smaller side of things, IMHO. With the compression ratio/intake/heads combo, I would think something near a 234/236 .592/.581 113+3 LSA.
HAHAHA--with those mods and a stock TC??? Look into the Circle D 11" 3000 stall for $375.
I would not run that healthy of a cam on a stock converter. It would need to be significantly smaller....maybe like a 216/218 .542/.535 114+2 LSA cam.
I talked to john at thunder racing and he seemed to think the TR220-114 would be ok with the stock converter. If I was to go with say a 2500-3000 stall converter would it affect my fuel economy?
