Results 1 to 10 of 14
Thread: help with my build guys
    Nov 2009
    ok, so i get to start blank with 5.3 litre, i was gonna go boosted but my girlfrieds car decided to blow a head gasket today and she drove it home. and now it will not move cause the block is seized very excited. so anyways i get to do a aggresive na build and hope for boost later. anyways, this is what i have planned
    243 heads
    i already have a 2800 stall
    comp 918 springs
    chromely push rods
    i was thinking about this cam @.050 227/241 .564/.547 109 LSA
    i love the way it sounds
    the guy who has it right now has it in a 4.8 with no stall but ive been told id need like a 3500+ cam for it to even run right.
    im also looking into a flt stage 4
    thoughts on a cam? would this cam work? what would you recomend? anything is very appreciated. very new to lsx engines and very excited to build this engine. i already have 4.56 gearing and some bolt ons all in my sig
    thanks guys
    Today 03:25 am 6 stringer o thats a good point, its ok ill just add a blinker fluid cooler
    Today 03:24 AMtruckinL33 that's not a good place for it, you can overheat your blinker fluid with the capacitor
    Today 03:23 AMtruckinL33 i need them for when i go back to 1985
    Today 03:23 AM6stringer i mounted my flux capacitor next to my blinker fluid resevoir
    Today 03:22 AMtruckinL33 me too, right next to my flux compasator!
    Today 03:22 AM6stringer hey gear oil needs to be cooled, i have front and rear diff coolers
    Feb 2008
    Shreveport, La
    that cam would be good for N/A or nitrous. but horrible for boost. I'm in the process of going boost I had to get rid of my ASA cam cause it would not work with boost very well at all
    txstvanwilder: but i got lube so i didnt complain
    mean05: he told me a price and i bent over and lubed up
    truckinL33: 6'' is not enough, and 12'' is too much
    pcmcobra: don't drink and bid on egay...lol
    408.Luke: lol im not blowing im investing
    Not a fan of the cam choice, but to each his own. I'll be running a 228R (228/228 .588/.588 112LSA) with a 3600 stall.
    Nov 2009
    chicago, il
    That cam will take too much compression out of your engine, and it won't run very well. It would make nice power at high rpm, but you will lose too much down low and more thank likely you would regret it. I would look into comp cams LSR cams for the 5.3. Those are some sweet cams for dd. Your stall and gear ratio you have now would be pretty well matched with the LSR cams.
    Southern WI
    That's the comp mutha thumpr cam..I've heard good and bad things about it. If your staying with the 2800 I'd go with the 212/218 or the tr220, but that's just me. I'm sure I'll get some for this but to be honest if you plan to do nitrous later on...the ls1 hotcam is awesome on it, I know this first hand.
    Mike
    2000 RCSB
    '05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
    Nov 2009
    well i got the cam for 200 and looking at a 3200 stall. should work better
    I still wouldn't use it. Its more for sound than performance. The best cam I've seen on a 5.3 yet is probably Garrissons or bluecajuns.
    Mar 2007
    Newark, Delaware
    I hope your planning on milling those 243's.
    Nov 2009
    already have a appointment small port and polish wirh a .20 or .30 mil
    Birmingham, AL
    .020 or .030 not .2 or .3
    just to make sure youre clear...
    another thing that ive thought about since we talked about it last is since youre lifted with id have to assume big ole tires, a smaller torqueier cam with the 2800 stall would probably better ofver a huge cam/stall. sorry i never said that before....
    what you guys think?
    01 Silverado
