Results 1 to 10 of 29
Thread: LQ4 Build
    Paris, Texas
    LQ4 Build
    11-18-09: This is my LQ4 that i got out of an 07 3/4 ton work truck. I will be doing my research and taking my time picking my combo out. I am going NA with it, looking for about 9.8-10.2 CR. I've talked with Richard at West Coast Cylinder Heads for P&P my heads, some milling, new valves, and dual springs. Looking into some forged pistons, the GT2-3 cam, and a TB stall. While I'm in there i will be putting some LPP or Pacesetter headers in with 3 inch exhaust with a Magnaflow single in/dual out muffler
    This is so i can keep some notes online.
    Any advice or tips would be greatly apprieciated.
    Paris, Texas
    If you have a suggestion on a better part, or if I have the wrong information, please let me know because this is my first Gen 3 build.
    P&P heads come with Patriot dual springs rated at .650 lift, 375 open pressure,
    heads milled .035-.040 with a 66-69cc chamber
    Lingenfelter GT2-3 cam - 207/220 .571/.578 118.5 (still undecided on)
    GMPP LS6 springs rated at .580 lift - 12586484
    Comp non-adjustable timing set - 3153KT
    Crank bolt - GM # 12557840
    Comp hardend pushrods - (can't get length until i figure out how much the heads are milled)
    Walbro 255gph - GSS341 (if needed)
    GMPP Lifters - 12499225
    Added:ARP head bolts, 04 & later - 134-3610
    ARP header bolts - 434-1301
    ARP cam retainer plate bolts - 134-1002
    ARP cam sprocket bolts - 134-1003
    ARP rod bolts - 134-6006
    ARP main bolts - 234-5608
    ARP crank bolt - 234-2503
    for starters that cr isto low for a NA build, thats more for a forced induction build.. you would wanna see 11:1 cr
    Simple: 408 on steroids!
    single digits coming soon!
    Gramercy
    go ARP head bolts imo. better to have to tq them down twice vs tq it then turn it 90* then another 90* or some crap.
    if youd rather use stock head bolts i have a BNIB set ive changed my mind on. pm me if you want them.
    id stay with the 7,000rpm lifters no need for the 8,000+ lifters you'll never spin that motor that high imo
    go with an ARP crank bolt an stay away from the LS6 springs. if your doing p&p heads from wcch do them right with the patriot extremes for 20.00 more
    seems like a good build so far.
    why'd you buy such a new motor if your gonna rebuild it anyways? just asking
    2008 GMC CCSB 6.2/6L80e swap
    Paris, Texas
    i am going for a good dependable street truck. what is your cr?
    what is the limit on milling the heads without having to worry about piston to valve clearance with dished pistons?
    Paris, Texas
    Quote Originally Posted by keniff View Post
    the truck had 128K miles on it, with a noticeable loss of power. it was pulled on the lift under its own power but only had like 90 to 120 pounds of compresson on 2 cylinders, and they said the cam had grooves in some of the lobes. i only paid the core charge for the motor.
    i run 11:1 cr on my setup and yes i do drive it daily..
    maybe not as much as i used to since i have 4 trucks and a car lol
    but anyway the lq4 is already at 10.5.1 or close to it, you talked to richard at wcch i would talk to him again and mention what you want out your build, if hes gonna do the P&P on the heads let him know you want 11:1 cr he will mill them why he has the heads, let him know youre wanting to run a NA setup.. he'll give you good advice on a street strip combo
    Paris, Texas
    Quote Originally Posted by skeet View Post
    everywhere i have read, they(lq4) come from the factory are 9.4 to 1, the lq9 is 10.1 to 1
    Quote Originally Posted by sierraman View Post
    i stand corrected, thank you, dunno what i was thinking, but youre right..
    but all in all whatever you wanna chieve i would talk to wcch, they deffinately know what there doing and give ya better advice on your build.. but 11:1 is still good cr for daily driving
    Paris, Texas
    it's cool man. what about the fuel system?
    should i stick with my factory pump and injectorys or upgrade to like a walbro 255 and flex fuel injectors, or should i upgrade to something a little bigger?
