Results 1 to 6 of 6
Thread: cat, and rear o2 delete
    Nov 2009
    Spring, TX
    if i take out the cats and the rear o2 censors will a nelson tune be able to make a program to turn off the check engine light, and will it be able to pass inspection with the tune
    Cromwell, CT
    Do they do a visual inspection for cats in tx? they still do it here in CT even on OBDII cars
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Quote Originally Posted by michaelweston1@yahoo.com View Post
    nelson can delete the rear o2s if need be. i would leave the o2 sensors connected just have him turn them off. if you remove the cats it might be tough to get inspected all cities are different like where i live they dont do a sniffer test but may do a visual.. but then again i slide the guy an extra 10 and go on my way
    Simple: 408 on steroids!
    single digits coming soon!
    Cedar Park, TX
    Quote Originally Posted by straightaxle View Post
    it depends on where you go for the inspection. Most places dont but some will. I went to Jiffy Lube in Cedar Park and all they did was an OBD test and fuel pressure test.
    R.I.P Blue '02
    '08 - 5.3
    Vette Servo, Flowmaster 40
    Oct 2007
    yes... they will click a few boxes and the pcm wont cel it..
    fwiw, i'd leave the cats on (unless theyre clogged) till you've figured out what you want, you may want your stock y intact one day
    02 Sierra... motorless for now.
    02 SS.. stock bottom 4.8, 241's, 224-220/116+4, 918's and pushrods, front mount turbonetics 78mm, HKS GTII, TiAL, eBoost2, Yank PT3600, Performabuilt 60e, solid motor mounts. Tuned by me with HP Pro and LM2/AFX
    Quote Originally Posted by SoHo48 View Post
    +1
