Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 49
Thread: bye 8.6" axle, hello 10.5" axle
    Finally time to start living up to my name, I'm swapping up to a better rear axle assembly. The truck is an '06 Sierra 1500 WT, 2wd, std. cab, long box. It has a 4.3L V6, 4L60E, and 3.23:1 10-bolt. It has stock steel 17" 6-lug wheels on 10-ply LT245/70R17E tires. It is for vacation use. It does okay hauling the 16-foot camper trailer, but we also have a slide-in camper, the kind with a bed above the cab of the pickup. This past summer I loaded that, and drove it 8 miles to the scales. 7,400# is 1,200# too heavy, but the 2500s were rated to 7,700#, so I knew what to do. No, not trade trucks. Especially since having the camper on there had no effect at all on the front ride height. I measured and re-measured.
    So yesterday I got a 14-bolt rear axle assembly from my local branch of LKQ Home, for $500. It has 84,000 miles on it. For $100 more, I coulda gotten one with 75,000 miles. I chose 4.10:1 gearing, since they weren't listing any with 4.56:1 gears. I was expecting the 8-lug pattern, but wasn't sure about the brakes. I got discs, but my truck came with drums. The axle is from an '03, so I'm expecting the spring pads and shock mounts to be in the correct places, and the overall width to be very similar to the 10-bolt.
    The reason for this thread is to detail how I resolve the issues of different bolt patterns, and different brakes. I expect to finish this thread by July 4, 2010.
    Sallisaw OK
    take pics
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    Nice. Let us know how it all turns out.
    It would have been nice to get the 6 lug 14 bolt from the 2WD SSS/VortecMax trucks.
    Cromwell, CT
    If you want to keep the disks in back you'll need the 4 wheel disk master cyl and propotioning valve. Maybe the 99-04 half ton stuff would work. As for the wheels... have you thought about converting the front to 8 lug rather thatn the back to 6 lug? I don't know of a cheap and easy way to put 6 lug wheels on an 8 lug truck but you can buy adapters to put 8 lug wheels on a six lug axle.
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    I wasn't aware there were any 6 lug 10.5s offered by GM, but it wouldn't've done me any good anyway. I'm seriously considering just carrying 2 spares. There's just not that much of a downside to it. As for the brakes, I appreciate the tip, Thank you.
    Houston
    the sss 14 bolts are a 9.5 14 bolt, but they are a 33 spline compared to the 10.5's 30 spline (i believe)
    408luke, I do believe the 10.5's 30-spline is larger than passenger-car 33 spline, and either way, this is a 2WD 4.3L auto-trans combo, so the axleshaft torque capacity isn't an issue.
    no progress this week.
