Results 1 to 3 of 3
Thread: LSx lifters
    Nov 2009
    cstat tx!
    LSx lifters
    can these lifters be put in backwards? the priming hole is only on one side and the oil passage is on the cylinder side of the block... if the priming hole is facing the intake will they not get oiled properly??
    thanks!
    j
    Jun 2009
    Washington DC
    the feed hole does not require any particular orientation, if they are stock. Aftermarket will be per the manufacturers instructions.
    Nov 2009
    cstat tx!
    Quote Originally Posted by Mang213 View Post
    Well that's not what I wanted to hear! My ls1 started making noise and 3 were flip flopped, was hoping that was part of the issue. How solid should the lifters be when out of the engine? I cannot depress them at all!
