ok the builder wants me to run this cam on my setup 224/230 .581/.600 110+2
isn't that a na cam?
Mods:
Maybe STOCK
"My lugnuts require more torque than your ricer is ever going to produce"
Sleep: That Stuff Is Overrated
"You don't care what it is, or who makes it, as long as they race it. You my friend are a true Gear Head!" (Drew Anderson)
Who's the real culprit of Obeisity: video games because their scared of physical activities, or Pillsbury for being so delicious?
The lsa isn't the best for FI applications and would bleed boost.
Sorry, I haven't been paying attention to your build... what are the build specs? Motor, heads, intake, shift points etc. etc.?
434 HKE wcch l92s lsxr about 400 rpm before it stops making power
Mods:
Maybe STOCK
yeah i wouldn't go lower than a 114 lsa
Your building a 7.0+L engine at HKE in houston..... with L92s from WCCH out in cali... ( GREAT engine shop and my choice for my motor) with a set of heads that flow bad GREAT but dont hold up well to big boost...and odd cam specs.. i know the l92 stuff is a bit different... this motor 10:1 compression??? and i agree not my choice for camshaft...... Not to bash you... but had to follow.........
thats a wild combo..
why so casey
Mods:
Maybe STOCK
o btw some where between an 88-101 haven decided and my buddy from garrett has to do some more digging
Mods:
Maybe STOCK
under standable but got a very good deal on the short block and a awsome deal on the heads lets just say i have a set of stock wheels in the heads lol and a left nut in the short block and im not being sarcastic about the left nut thing
Mods:
Maybe STOCK
