What are you guys running?
 Member
						Member
 Senior Member
						Senior Member
						one of those conairs but the wife wont let me install it
lol theres a few boosted trucks on here, maybe they'll chime in soon!!
Simple: 408 on steroids!
single digits coming soon!
 Member
						Member
						hopefully
76mm Turbonetics .96 AR
I like it but I think for a 6.0 the ar is a little too big might should have a .88ar
Otherwise I love it. I have heard some horror stories about turbonetics eating themselves and taking the motor with it when pieces of the turbine wheel go into the motor.
I have reall good things about master power turbos.
garrett or master power seem to be bigger on a lot of other forums (for different cars)
turbonetics is also a very large player in the game (seems like that is number 1 choice around here), lots of horror stories, but if enough people run them, that will happen no matter what.
I run an 82mm (formerly 80mm before rebuild). I bought it used. The turbine housing is a Turbonetics. The compressor is a ITS. ITS is Innovative Turbo Systems which is now out of business but the same guys now operate Comp Turbo. No complaints about the turbo. Get's the job done.
 Senior Member
						Senior Member
						Here's my list on my truck...
4.8 STS
60-1 Garrett, .68 a/r
Master Power T70, .68
Back to 60-1
4.8 KB Racing front mount
60-1 Garrett, .68
Master Power T70 .68 (505 rwhp @ 11psi)
5.7 LS1 KB Racing front mount
Master Power T70 .68 (12.2@110mph, almost 8k DA, 15psi)
Master Power T70 .96 a/r (broke tranny night before going to the track)
Master power T76 .96 a/r (12.2@110mph, 2500 DA, 10psi, broke tranny at 13psi)
Master Power T76 .96 a/r -> Radix TVS1900 (too much back pressure)
Borg Warner S475 1.36 a/r -> Radix TVS1900 (12.6@109, 7500DA, 12psi)
Borg Warner S475 1.36 a/r (with quick spool valve 12.66@112mph 9psi, valve not opening right, needed more testing time)
Coming......
Borg Warner S480 1.10 a/r (w/about 75 shot out of the hole)
01 ECSB 1/2 ton 4x4 6L GMC
11.03@127
KB Racing Borg Warner S475 turbocharged
I like it and think it is perfect for the 5.7 LS1. Best run to date 11.86@115mph 10psi.
STS w/Master Power T-70 .68 A/R. Going to the track tonight to get some new times!!
