Results 1 to 10 of 14
Thread: Trailblazer Converter behind 4.8
    Mar 2008
    Burleson, Texas
    I am going to do a performance rebuild soon on the 4l60E and want a converter at the same time. I know a lot of people like the TB converter on the 5.3 and 6.0 motors, but will it help as much on a 4.8 with less torque? The reason I ask is the trans kit is going to be pretty expensive already and the TB is only around $200 vs $350 and up for aftermarket.
    '00 Silverado 4.8L (Gone)
    '11 Silverado 4.8L
    Quote Originally Posted by RUFFNECK View Post
    ...First relieve the pressure before doin' that or else you will get a nasty squirt and may get in ur eye.
    Sure, get the verter from a TB with the inline 6 cyl. if you want to save some coin... it's a nice upgrade vs. stock
    Mar 2008
    Burleson, Texas
    That's the goal, it's hard to go fast and pay for school at the same time. I can get the I6 converter cheap from work, just wanted to make sure it would be worth it. I know the bigger motors (6.0) typically give a higher stall and didn't know if my 4.8 would benefit much. Are there any negative effects?
    '11 Silverado 4.8L
    Quote Originally Posted by DBTBSS View Post
    Welcome to the site. Who are you???
    Yean man--the verter from the I-6 TB is the best. Behind a decent V8, it will stall around 2300-2400 rpms.
    Okeechobee, Fl
    Before u buy a tb stall atleast check out ls1tech.com for around a 3000 circle d, yank, or any other good companies...
    I got my Circle D slightly used from a guy switching to a 4l80 that just needed the verter gone and I got a very good deal!
    49 Ford F1
    Pittsburgh, PA
    tb stall behind a 4.8 seen 2k. not enough torque of motor to really see the true gain
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    I swapped one into a 5.3 with mods and even at bargain basement price he paid for the unit and no labor, it was not worth the effort from what I hear. A reworked TBstall by Circle D is probably yet another issue all together and is probably worth the effort.
    S.A. Texas
    I run the Circle D TB verter. I love it. Their customer service is second to none. go for it.
    wichita falls, tx
    im with nate...not worth it in my RCSB with a 5.3, i can only imagine its really less noticeable with a smaller motor
    Intro Radicalli's
    There's my example
    A C-D rework is another story as described above.
