I just got Keisler Engineering to compile a quote for anybody who has ever been interested in putting an early model Muncie M22/21, or T-10/SuperT-10 style transmission behind an LS style engine. This is really handy for retrofitting ls engines to 60's gm muscle cars while keeping the same transmission and drivetrain. so here are the specs and descriptions along with prices.
Keisler Engineering, Inc.
2250 Stock Creek Blvd
Rockford, TN 37853
Due Date Terms
10/15/2009
Rep
865-609-8187 X1 Sales
865-609-8287 Fax
email: sales@keislerauto.com web: tremec | 5 speed | 6 speed transmission | Classic car restoration | hydraulic clutch kit | ford transmissions | chevy transmission | dodge transmission
02 SILVERADO AT
621 Reproduction GM bellhousing for LS series engines, re-engineered by Keisler with thick wall titanium-aluminum alloy construction and CNC machined
in-house. 168 tooth flywheel Best 621 reproduction bell on the market- MADE IN USA!
239.95
ROLLER PILOT BEARING ASSEMBLY FOR JAGUAR 5.3L, GM LS, AND
OLDSMOBILE
49.00
FWG-460535R, LS FLYWHEEL, LIGHTWEIGHT 17LB FORGED STEEL,
168TOOTH, FOR STANDARD 11 & 12 INCH CLUTCH, INCLUDES DOWEL
PIN KIT FOR LS CLUTCH (LIST $499)
325.00T
GM LS FLYWHEEL BOLTS, SET OF 6 1 26.95T
CLG-PK1877-04, 11' 1-1/8 X 26 SPLINE HIGH PERFORMANCE CLUTCH KIT
FOR GM, 650 FT-LB RATED, INCL: MODERN PEDAL EFFORT NODULAR
IRON PRESSURE PLATE, HIGH TORQUE CLUTCH DISK WITH REBOUND
CONTROL, PREMIUM USA SEALED RELEASE BEARING, ALIGNMENT
TOOL, LUBE PACK
299.00T
#910 GM/MOPAR PRESSURE PLATE BOLT, SET OF 6 1 15.95T
HYDRAULIC CLUTCH ACTUATOR PACKAGE FOR STREET ROD/TRUCK
WITH GM DRIVETRAIN AND MUNCIE 4-SPEED, INCL: MASTER CYL,
HYDRAULIC THROW-OUT BEARING, RESERVOIR ASSEMBLY, FLUID
LINES, FITTING KIT, INSTRUCTIONS
599.95T
SHIPPING AND HANDLING 69.00
Out-of-state sale, exempt from sales tax 0.00
$1,624.80
