Results 1 to 2 of 2
Thread: Rearend Question
    Needville,TX
    Rearend Question
    I want to do a couple of tests with my rearend regarding the vibrations.
    Question is can I remove the axle shafts and spin the carrier assembly(with fluid) to see if the vibs go away?
    And if the vib is still there can I pull the carrier assembly and just spin the pinion?
    Basically I just want to run it up to 70mph at the most 2 times.
    Right now I noticed the drivers side outer axle bearing is starting to make noise when turning.
    I doubt its the cause of the vibration though!
    89' GMC RCSB 6.0L LQ4, T56, 4.56 Gears
    Evant,tx
    a bad wheelbearing can cause a vibration ive seen it my moms car did that have u checked your u-joints ive seen them not bad but dry and rusty and causes them to be stiff
