Results 1 to 10 of 15
Thread: 7.0 427
    Question 7.0 427
    do all 7.0 427's have to run the dry sump oiling system?
    Sep 2009
    outside Las Vegas
    as far as i know only the ls7 runs a dry sump all the older years from like 66 to 70 something were not
    FOR SALE!!! 6.0l Vmax motor 3000mi with 4l80e $3400
    Quote Originally Posted by VMAXDAVE View Post
    Yeah, really...and those engines have nothing the do with the design of the newer engine.
    GM has already used the LS6 and LS7 option numbers before and they were waaaay different animals (BBC's).
    Tyler, TX
    the only reason the 7.0L's run the dry sump systems, is because they were built primarily for GMs Corvette Racing Division which is mainly autocross racing, and that involves alot of highspeed, long sweeping turns. and unless you have a dry sump system in this situation, you'll suck the pan dry. for a street car, you can use the standard oiling system with no problem, you might want to install an oil restrictor though to give it priority main oiling.
    www.tjc.edu
    ok thanks so i can go around it then and run the stock oiling setup.
    Quote Originally Posted by STUNNA View Post
    Absolutely.
    I thought the dry sump had 2 oil pumps and a longer crank which allowed for the dry sump set up? Not sure how the conversion would work...
    Jun 2009
    Washington DC
    You cant adapt to a wet sump because of the crank, as far as I know, but people are clever and there may be an adapter/conversion on the market with a different pump and pan
    Just buy an LSX block and be done with it.
    Did you know you can change the lifters in an lsx block with out removing the heads.
    Jun 2009
    Washington DC
    Quote Originally Posted by zeake View Post
    You can do that in any LS motor, because of the plastic lifter trays. Not just the LSX, which is just an optimized iron block anyways (not a complete engine)
