I have been putting everthing in a pile in the corner of my garage for a couple of weeks for the 4L80e swap and I am still not sure what to do with the driveshaft, the truck is a 2wd CC 1/2 ton with the 143" wheel base and a 5" aluminum one piece driveshaft. Dennys drive shaft said I would need to get a two piece driveshaft for the power that I will be putting down and he said do not use the longer 32 spline slip yoke, and the shaft right now is about 82"'s long so what will need to be done to do the swap?
