Results 1 to 10 of 16
Thread: i want e fans
    i want e fans
    i'm tired of the wind noise from the darn fan. what do i need to make this as clean as possible, almost stock like, and done right (harnest, fans, ect.)? keep in mind of my body lift.
    there is probably a write up on this but oh well itll be good conversation lol
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    Fort Worth, Texas
    Do like I did, 2005 and up Silverado. You get the 34 inch radiator and the bolt on fans, get with Nelson Performance for the harness and have Dale update your tune to run them. Super clean factory look and they will work with your BL....
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    alright are the e fan radiators bigger then the stock one i have now? any extra brackets i will need?
    I might have a full OEM 34" fan set up and a Nelson harness for sale soon. You'll wanna get the larger radiator.
    there u go nortex^^
    Fort Worth, Texas
    Quote Originally Posted by NorTex4x4 View Post
    I believe your stocker is like 28-29 inches and the bigger one for the 2005 Silvy EFans are 34 inch. No brackets required bolts right up to your core support, might need a 2 bolts for the fans since the ones you need are a bit bigger than the factory shroud bolts, but I bet Nat will give everything you need for the mod.
    Sweet, I'd be all over this....
    2004 Tahoe LT
    1971 Chevy C10
    Alright GasGuzzler im in on that. pm me a price to what you might well it for and i would be glad to purchase that from you. i wanna know if i have the cash already or how much id need to save. know what i mean? btw.. you da man!
    gg if u ever run into the bumper side caps with foglights let me know for gmt900 chevy
    Lakes Region NH
    Does anyone have the GM part number for the 05-07 fans as well as the 34" radiatior?
    Ill grab some ditch to get a cat...
    03 Silverado ECSB - SOLD
    06 CCSB Duramax - 12 second tow pig
    Quote Originally Posted by CooperS7777 View Post
    its gonna be alot of part numbers and expensive cause gm pokes everyones eyes and sell everything seperate,,,fans,motors,shroud,blade.etc etc
