I just put this vaccum line didtribution block on my truck to run wastegate, bov, etc... took the truck for a spin and at wide open throttle pulls low 11s and then all the sudden jumps to like high 15s, what would cause this,, nick
Master power t-76 kbracing, Intercooled, 11psi, tr220 cam, patriot dual springs, 72lbrs, snow meth, walbro, efans, 80e, tansgo, yank 3200.
Either your 02 sensor is bad or your MAF is contaminated. Both have happened to me.
would a obd scanner tell if the maf was bad I no it should tell me if the o2 is bad
and another ? is the rear o2s the same as the front since I am not using them anymore could just swap out
The OBD II will not tell you if the MAF is bad. I had to remove it, clean it and put it back in. As for the 02 sensor, it depends on what wideband you have. I know my AEM uses a Bosch wideband 02 sensor. The front and rear 02 sensors are different - upstream and downstream. Your best bet would be to find out exactly which 02 sensor your wideband kit uses and replace it. My wideband 02 sensor only lasted about a year.
