Results 1 to 4 of 4
Thread: Front End Vibes
    Sep 2009
    Florida
    Front End Vibes
    Well at about 65 to 70 my truck starts to shake in the front end. I just rebalanced my tires and replaced the lower tre bushings. Any thoughts? What does your torque converter feel like when it goes out? I have a stock 99 rcsb with a 4.8
    Mike
    07 Avalanche LT1 w/5.3 We call her Ava
    Lancaster PA
    Did you look to see if you have a tire out-of-round or a possible shifted belt? I suggest rotating tires front to back and see if that solves it. Good luck.
    04 GMC Regency - Building a 6.0 Comp 7.4" Hi-Tech Pushrods, Patriot Performance 8401 Spring Kit, Comp Double Roller Timing Chain, ARP Rod Bolts, ARP Head Bolts, Cam - I dont know yet, any suggestions???
    89 Chevy Cheyenne - 10/24/09 Time of death declaired at 8:16pm.
    Maui, HI
    Check your Idler and Pitman arm along with the inner/outer tie rods.
    99 Silverado 1500 4x4 RC 4.8
    4L60E, 3.73, Homemade CAI, 92oct Quik tuned,
    08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
    Sep 2009
    Florida
    Quote Originally Posted by Sargen View Post
    It's got brand new tires and it was doing this before I got them. I will check all the other stuff and post up.
    Mike
