Results 1 to 5 of 5
Thread: pushrod question for 6.0 build
    wtby ct
    so im getting down to grabbing all my parts for my 6.0 swap and im going with a 05 6.0 with a set of L92 heads and intake and a z06 cam.my question is what pushrods do i use with these heads are they still the same length as stock??also do u think its worth porting the heads for this camshaft or wont really see much improvement.thanks....VJ
    2001 Suburban 1500 5.3 4x4 Lt
    WHATS DONE SO FAR- CAI, 3inch Cat back with flowmaster,2-3 inch drop,rebuilt trans with hd2 transgo,TB Converter,aftermarket trans cooler,Tinted tail lamps,Street
    Scene grille,hids,punched Cats,20 inch incubus wheels,07 front brake upgrade,clear corners
    WHATS IN THE WORKS- 2005 6.0L swap in the works,long tubes,Z06 cam,ls6 yellow springs,e fans,ported throttle body all to come shortly
    Nov 2006
    Mesquite, TX
    7.4 comp hardened pushrods and a little porting will only help the flow that much more
    Slimsilverado Guest
    get a bigger cam Bro....
    wtby ct
    why u think its too small??i thought they mad decent power?
    Slimsilverado Guest
    I think you could get a better cam than that. Call Nelson performance and get a custom cam....
