Results 1 to 10 of 11
Thread: Lines in my projectors! HELP!
    so this spring i bought some black projectors for my truck and since i put them in i have weird lines going across my headlights when they are on. I've tried adjusting them sum but still can't get rid of them! Didn't bother me too much before but now that i put my HID's in it bothers the heck outta me! Any help or suggestions is greatly appreciated!! (i've attatched a pic of what they look like against a building)
    Round Rock, Texas
    That's just how they are. I had a buddy buy some for his Camaro and they were the same way. Its the cutoff line so you don't blind oncoming traffic.
    Plainfield, IL
    you'll get used to it...
    ya i understand the cut off line part, it's just that they both have weird cuts in them and i can't get them to level out and stuff....ya i know i might get used to them but it kinda bugs me cuz they stick out bad.....oh well i guess.......
    Plainfield, IL
    ya, if the passenger side 'block off' was flipped it'd be alot less annoying. main reason I took mine off.
    Round Rock, Texas
    If you want to, you can take apart the headlights(open the case) and use a Dremel to flatten the little "Z" parts so that its a straight line. Make sure to seal the housing really good or water will get inside.
    Oleshifty,,,,what passanger "block off" are you talking about? so if i take the projector lense off there will be a little z in the front inside i can shave off? i don't mind the cut off line going across whatso ever, it's just that i can't get them to allign going across! And i played with them the other day and still can't get them to allign going across
    wichita falls, tx
    u can take those blockers out...that what i did when i had my black projectors, they looked just like yours before i took those plates out
    Intro Radicalli's
    Round Rock, Texas
    When you take the shields out does it still have the cutoff line, or does it blind everybody in front of you? I wish I would have taken pictures of my buddy's light when we did it. You have to seperate the clear lens(front of the light) from the back of the housing. Then you take the projector glass out and you will see a shield with a step>>(-|_) looking cut at the top. Grind it smooth and reassemble the light.
    banker099, the blocker's your refering to...are those the same little z shaped things on the lens's that everyone else is talking about? what's the best thing to shave them down with? a ROTO ZIP? CUZ i dont wanna scratch the projector lens
