Is the boost valve in the transgo kit's only purpose to raise the tranny line pressure?
2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
Not just line pressure, it raises internal case pressure.Originally posted by yeary01z71@Nov 10 2004, 07:48 PM
Your shifts too hard or something?
yeah, the 1-2 is getting really annoying, I pretty much can't use the tow/haul because it just jerks the shit out of the truck on the shift at the higher rpms and a heavy trailer behind it.....this shift kit has brought out so much banging and clanging in my driveline that i'm considering taking it out, the only part I was considering leaving in was the boost valve if it helps get oil to the bands and such better
Oh damn! You use the Tow/Haul with the TransGo setup you have?![]()
Well, why not just get you a new seperator plate?
Enlarge all the holes BUT the 1-2 clutch feed and make the 2-3 a bit larger only. Sounds like that'd be right for your needs. It'll tone down that 1-2 shift a ton...
With the TG setup you really don't need to use the Tow/Haul mode either. It really only bumps line pressure and raises shift points. You can always manually shift the truck yourself...
Well I didn't use the tow/haul very long!!!! It was a little too much. Thanks for the help and suggestions, i'll try that separator plate trick out.
Those new plates are cheap... maybe $12 or something like that and of an improved design over the OE part.Originally posted by yeary01z71@Nov 11 2004, 04:59 PM
I'll get you a link when I return home.![]()
Let me know how that goes. I have the same complaint as you with 0 washers and the vette servo.Originally posted by yeary01z71@Nov 11 2004, 05:59 PM
Andrew
Andrew
2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
How big did you drill out your feed hole for the 1-2? Still on a stock trans or is it built?Originally posted by agreif@Nov 12 2004, 01:27 PM
Andrew
Remeber performance frictions and band will shift a lot firmer than stock too...
If it's STILL too bad, put in a softer 1-2 accumulator spring too.
I think if you have tuning done, you can lower the line pressure for normal shifts and it will still be high for WOT. You can also add some torque management under normal driving to soften the shifts.
Hey man, I got your i.m., whenever my wife logs onto her user account on xp it always says i'm logged on too. Stupid computers! I'll probably try putting the stock accumulator springs back in.Originally posted by Hit Man X+Nov 12 2004, 12:18 PM--><div class='quotetop'>QUOTE(Hit Man X @ Nov 12 2004, 12:18 PM)</div><!--QuoteBegin-yeary01z71Those new plates are cheap... maybe $12 or something like that and of an improved design over the OE part.@Nov 11 2004, 04:59 PM
I'll get you a link when I return home.[/b]
