Results 1 to 10 of 11
Thread: Light 17" wheels???
    Feb 2008
    Arizona
    Light 17" wheels???
    Guys, i do sand drags most of the time and that's why I bought 285-70R17 BF Mud terrains, they perform very nice in the sand but as you should know they kill me in the street.. I'm looking for a set of 17" wheels in the 8.5-10" width range that are lighter that my 45-50lbs stock wheels to try to compensate the weight I add with the mudders instead of my stock tires.. The lighter the better.. I really like centerlines stingrays but I'm not sure if they are light or they are made in 17"..
    (I was going to buy dick cepek DC-1's 24lbs each but i don't like them that much, they just got my attention cause of the weight)
    Should I look for aluminum wheels? Forged? Or what kind of wheels are lighter??
    Thanks!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    Quote Originally Posted by White Devil View Post
    ....I really like centerlines stingrays but I'm not sure if they are light or they are made in 17"..
    They are made in 16", 17", 18", 20", and 22".
    Billet aluminum are pretty dang light. They are stronger and lighter than your stock wheels. But if you wanted to spend some real $$$, you could buy some ultra light Magnesium wheels...
    S.A. Texas
    Centerline Wheels
    here ya go 17's they are 20lbs should be light enough
    GA
    damn i want a set but 800 bucks is alot for some 18s and no tire
    04 5.3
    224/224 .566 .566 114
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    S.A. Texas
    Quote Originally Posted by static04 View Post
    aww those are billet you will not find another billet wheel that cheap.
    GA
    oh yea i know i just dont want to spend that much on wheels right now lol
    04 5.3
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    Quote Originally Posted by murdered_outgmc View Post
    +1
    Feb 2008
    Arizona
    Somebody told me here on the forum that my stock wheels where 45-50lbs a piece.. I just did a lot of weighting yesterday and my stock wheels turned out to weight 20lbs.. The stock tires that came from factory 31lbs and the mudders that Im running right now weight 57lbs.. 26lbs of difference between the factory tires and mudders :/
    so, 20lbs are hard to beat in my opinion.. 17" Stingrays weight around the same..
    Fort Worth, TX
    lookup the pro comp 1069 and/or 1079 series for 6 x 5.5 and there is a set of 17 x 9 tht weight 22 lbs. in hubcentric. i acctually run my slicks on the 1069 (non beadlock version) 16 x 10
    05 Silverado RCSB...
    LQ9, TVS 1900, 4L80e, & EFI live.
    07 Silverado VortecMAX CCSB LTZ Z-71...
    Stock... so far
    08 Cadillac Escalade 6.2 / 6.0... Wife wagon
    Fort Worth, TX
    btw the procomp wheels are cast alluminum for 140 each @ 4wheelparts.com
    Stock... so far
