Results 1 to 10 of 16
Thread: Factory speakers are starting to fail.
    Sep 2009
    Beaufort, South Carolina
    I have a 2006 crew cab with the factory head unit and factory speakers. My problem is that my speakers are starting to fail one at a time. It started with the front passenger woofer and moved to the front driverside woofer and now it has moved to the rear passenger speaker. The tweeters still work and the front driverside woofer will work when it is really hot outside. Could it be the radio or the speakers? Any help would be greatly appreciated.
    Most likely speakers although that's a lot of failures in one truck.
    What are your U-codes?
    Sep 2009
    u-codes?
    On the label in the glove box.
    Sep 2009
    U 8555
    Sep 2009
    or do mean the 3 letter codes that have a u in them?
    Yeah...the 8555 is the paint color.
    UQ5?
    Sep 2009
    Au0, Au3, Ciu, Gu5, Kup, Ub0, Uq3, 41u
    Sep 2009
    Ciu should be C1U.
    UQ3 is what I was looking for. You have bad speakers. Get some OK aftermarkets that fit in the stock location and you'll be happy.
