I've got an 04 silverado with idle problems any ideas what it could be. 5.3l motor when i pull in the drive way it tries to die sitting at a red light it jumps around.
he had a hypertech on it but took it off to see if it changed anything and no mods.
i'm not changing names trucktrix is a friend of mine sorry
no tried to check the fuel filter found out it wasin the gas tank i was told it could be carbon build up in the throttle body
is the iac riveted in or screwed in?
nevermind its riveted in
Try cleaning your maf sensor first.
