Results 1 to 10 of 10
Thread: 8.5 8.6 10 ring/pinion the same??
    Question 8.5 8.6 10 ring/pinion the same??
    wondering cause i heard the 8.5 are harder to install in pickups??or are they the same crap?jegs has them listed 8.5,,then motive has them listed 8.5 8.6???????confused lol
    Augusta, Ks
    Can be used but bearings need to be swapped too.
    2004 Buell XB12s
    Fort Worth, Texas
    You can put an 8.5 ring/pinion in place of the 8.6's, but I don't think you can go the other way. When we set up my gears the 8.5 had more backlash than the 8.6 did, i.e. the 8.6 is set up tighter. I would say they would be the same to set up not really harder, just a touch more time involved getting the 8.6's backlash right since it's a bit tighter.
    +1 on swapping the bearings...
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    ill be going with 8.6 for a direct swap
    Round Rock, TX
    They are the same.... and backlash settings are the same.....The difference is the carrier bearings, they make bearings that will allow a 8.5 carrier to work in a 8.6 rear end but not the other way...
    .008-.012 is the settings for 8.5/8.6
    Quote Originally Posted by DBRODS View Post
    You don't work with suspension or rear ends. You don't know! Didn't you screw up a Moser last week?
    Round Rock, TX
    yes i effed up and ordered a narrowed axle that was 27 3/8'' instead of 27 3/4''...it was a small typo...
    Just messing with you bud.
    FWIW I would put the BL at more like 4 or 5 if using GM gears and 8.6 stuff but no one here probably would so....
    got a good deal on 4.10 8.6 from rons machine shop
