Results 1 to 7 of 7
Thread: 05 fans
    Aug 2004
    On the 05 electric fans..do you have to buy them piece by piece or is there a part number jus to buy the whole assembly...I have all the part number from previous posts jus wondered...hoping to do the fans next...
    04 crew cab Chevy, 5.3L, Diablo Predator, Airraid MIT. K&N drop in, 3 in/out Flowmaster, 2 chamber 40 series delta flow
    Jun 2003
    i think you still have to order them in pieces remember they are designed for a 34" rad to.
    04 supercrew 5.4 3 valve-magnaflow catback
    formerly 02denali 12.79@107
    Aug 2004
    Yea, I have the 34 inch radiator...jus wasnt sure it I could get it as one unit or pieces..thanx
    Aug 2003
    Spring, TX
    Will these fans work on a 01 truck and be able to be controlled by the pcm? I don't know if I have a 34" rad but I think I don't.
    -leo-
    2009 Silverado CC - 6.0L L76|6l80e|3.42s|4/7 drop w/ helper bags
    01 silverado ecsb - (RIP 04/2009)
    Jun 2003
    no leo you dont. you have a 28"
    Aug 2003
    Spring, TX
    Could I fit a 34" radiator where my stock one is at? How much are they and where can I get one?
    -leo-
    Nov 2004
    Victoria,Texas
    i work at a chevrolet dealer and just did this conversion. all the fan parts must be purchased piece by piece at this time.the list price for the motors is $55.00,blades are $32.65 each,shroud $61.80.I used terminal 42 at pcm connector c1.used ls1 edit to set the turn on temp at 160 deg.factory temp is set at 288 and the fan option is turned off.on the 05 p/u circut 33 at pcm connector c2 is the high speed turn on circut.on my 01 suburban circut 33 moniters the recirc request from the ac control head.i will probably hook the high speed to the ac compressor relay control
    circut for now.i am going to call delpi to see if there is another unused circur that will opperate the high speed control.
    01 1/2 ton suburban, 6.0L, MTI stelth 2 cam, MTI 2.055/1.60 heads, GMS Maf, 3200 yank, Dynatech headers, King cobra air intake, 42# marine injectors, 05 electric fans, ls1 edit, fourth set of 4.56 gears. Fast for a led sled.
