Results 1 to 4 of 4
Thread: fuel system upgrade
    wichita falls, tx
    fuel system upgrade
    ok so i have determined that i need to do something about my fuel system because it starts leaning out once i get into boost so what i think i am going to do is use my walboro 255 to lift up to a aeromotive 1000, then to -8 line up to a pressure regulator, to new rails then back to the tank with -6 line.
    What do yall guy think of this and also i need some help from some of yall guys that have run a system like this as far as parts and fittings and stuff like that.
    This is what i have found so far
    of course a aeromotive 1000
    and this regulator
    Aeromotive 13101 - Aeromotive A1000 Injected Bypass Fuel Pressure Regulators – SummitRacing.com
    im not sure what all fittings i might need so i need help with that
    Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
    EPS cam 23x/23x 600/603 112lsa
    KP 6 link bagged with Accuair E-Level
    http://www.nitrousexpress.com/
    Plainfield, IL
    search for midnight's ( i think thats part of his login) post. He just did a full fuel system, he's prolly the guy to talk to.
    Mar 2008
    Wichita Falls, Texas
    talk to Jason..Midnightrider...Trey he just did a fuel system..maybe a bit $$$ but with the power your truck is capable of making it maybe a good idea..
    How have ya been? Have not seen ya in a while..we need to have a little sonic GTG or something.
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=4251&dateline=1206558  920
    Jason has a lot more mods but would be a good source although your plan would probably work just fine.
