Results 1 to 9 of 9
Thread: tranny cooler and shift kit?
    Okeechobee, Fl
    Well I just bought a circle d stage 2 3400 converter. I know I need a cooler and im gonna get a transgo hd 2 to help this tranny live alittle longer.LOL!!
    But the ? is will a B&M 24000GVW cooler work? Or is there a certain one I need? Also where should it be located? 1 more i plan on getting a tranny temp guage too where should it be installed and will any one from summit work?
    Thanx in advance!
    49 Ford F1
    Oct 2008
    Cedar Park, texas
    Tru-Cool MAX transmission cooler with external thermal bypass: transmissioncoolers.us
    ^^^that one should work well, if you have a stock cooler than itll be right behind the grill.
    Axekick tuned, Pacesetters, Servo.
    Spring, Texas
    Quote Originally Posted by 06 4.8 View Post
    Thanx in advance!
    Here's one a little cheaper...
    TRANSMISSION COOLER HD 40,000 GVW TOW TOWING TRU-COOL:eBay Motors (item 120390737450 end time Sep-07-09 16:36:22 PDT)
    The 24,000 would work but with that stall I would get the 40k and not worry about it again. As far as a trans temp guage, you can get a SS/HD cluster that has one in it or an Aeroforce Interceptor Scan Guage.
    Houston
    congrats on the verter and id go with the ss or HD gauges just make sure u dont get D-MAX gauges as for the trans cooler idk much about them
    Jun 2009
    Washington DC
    I just bought the one that Ramair2002 suggested. It looks like its all youll ever need
    Spring, Texas
    Quote Originally Posted by Mang213 View Post
    Notice I suggested the same one here too....that's because I work on commission. Oh ya, you owe me $10!
    Jun 2009
    Washington DC
    the checks in the mail, bro
    Spring, Texas
    Sweet! I'll be waiting for it...
    The Denali and Escalade has trans temp too.
    Yes, get the 40K.
