Results 1 to 5 of 5
Thread: 4L60 fitting size?
    Spiro, Oklahoma
    4L60 fitting size?
    I'm buying the fitting to use steel braided hose for my transmission cooler lines but I can't find what sizes are used. anyone know? also is -6an large enough for the hose size?
    1991 Silverado-L33 5.3L, 212/218 .557 .562 115+4, ASP under drive pulley,180* thermostat, 90mm truck intake w/ LS3 throttle body. Shoenfeld conversion headers and duel Flowmaster exhaust. Performabuilt LVL 1 transmission and 23-2500 stall converter.
    Hutto TX
    Check it.
    TCI says 1/4 pipe thread.
    And if you forget which way the fluid is flowing on any trans.....looky!!
    TCI - TECHNICAL INFORMATION: Cooler Fittings
    1991 Silverado ECLB
    LM7-T56
    Bloomingdale Illinois
    Take a look at these. Vince
    4L60 & 4L80 Trans. Fittings -6 AN
    Spiro, Oklahoma
    Quote Originally Posted by r6z4o6 View Post
    Check it.
    Yeah 1/4 sounds about right, I only ask beacause the truck is about half the country away right now and i just wanted to have the parts waiting for me when i get home.
    Be careful if using 1/4 pipe threads. They are not an exact match to the threads in the trans. I have seen when they are overtightened that you run the risk of cracking the case. I have used them but if you do, do not be a gorilla when tightening them up. I use some red anaerobic sealer on the threads and just snug them up to the point where I am comfortable with them. Never go to the point to where they stop turning. That is when bad things happen. I would take a look at the link I provided. Those seem to be an easy solution and still use the factory fittings in the case. Just a thought. Vince
