Results 1 to 10 of 11
Thread: TH400 w/ T-brake
    Nov 2006
    Mesquite, TX
    TH400 w/ T-brake
    Selling my turbo 400 trans, has a full reverse manual valve body. Trans is fully built with billet/hardened shafts and all the best of the best stuff throughout, i can get a full build sheet for it...has a deep trans pan on it and -an fittings for the cooling lines.....paid $1400 for it....also has the VSS so your speedo will work..that alone was $250
    TH400 Art Carr converter, custom built to bolt the th400 directly the 60e flywheel...it was built for boost and will work great with the trans brake...paid $600
    The trans is being freshened up as we speak so it will be brand new and ready to go
    All of this for $1700
    Mar 2006
    Mesquite
    Someone with a modded truck with a stock 60e needs to jump on this and sell your 60e before it breaks...
    Birmingham, AL
    what all needs to be done to install this?? or is it just a bolt up and go type deal?
    01 Silverado
    Nov 2006
    Mesquite, TX
    it bolts right up to the block and flexplate, but the crossmember and DS will need modifying, the VSS plug just needs to be spliced into the factory wiring, I have the needed deal so the prndl switch bolts on fine but then you just need to decide what shifter you want to run...a after market B&M shifter sells for around $200 and thats about all i can think of
    Houston
    whats the stall on the converter?
    Mar 2006
    Mesquite
    3200ish
    Nov 2006
    Mesquite, TX
    ^^^what he said, it would foot brake to right around that with the boost
    Nov 2006
    Mesquite, TX
    Trans specs
    70 chevelle trans originally
    Trans brake with reverse full manual valve body
    Billet input and intermediate shafts
    32 Element Sprague
    Clutch hub
    Cast Drum
    rebuilt GM front pump
    Alto red clutches
    Deep aluminum pan
    Ooooo Good. The case etc. is older so it's from the real Torrington bearing area, should have no plastic washers. Mitch is the only person not allowed to consider this as what a step back it would be....then again, V wants to sell it....
    Nov 2006
    Mesquite, TX
    Sale Pending on the trans!
