Results 1 to 6 of 6
Thread: ls7 crank?
    ls7 crank?
    can this be used as a stroker crank for any lsx build? I might have found a deal on an ls7 crank that need to be re surfaced. I know it will hold the power I'm looking to make out of my next build. I'm planning an aluminum 383 from an ls1 block.
    as far as I know its the same, but I know there are some non interchangable parts between the gen 3 and 4 engines so I figured I would check.
    Thanks guys
    s10 with 4l60e and cammed 5.3 on the road!THREAD
    "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.".
    Reluctor wheel on the crank might need to be changed if memory serves. Dont trust me though.
    Houston
    the block will need clearencing like any 4in crank in a ls1 block some 6.0's u can get away with out it (like mine) but its nothing a Drimmel cant fix
    thanks guys! the reluctor wheel is something that can be swapped right?
    Houston
    yes, at least ive heard of people switching them idk if u have to heat it up to get it off or what
    Round Rock, TX
    i think the snout of the crank is different, has something to do with the dry sump oil pump. So I don't think they are swapable without alot of machine work. The reluctor wheel is easy to swap if you have the alignment tool. It has to be positioned a certain way or bad things will happen..
