Results 1 to 10 of 10
Thread: Dash/Extended cab door clips?
    Anyone know the part number? The genious that had the truck before me lost at least three from the dash and each swing out doors.
    Where is the post whore Nathan when you need him?
    I would have tried to help but I'm not sure what exactly he needs. Thanks for the invite Tyler.
    The little metal clips holding the door skin to the door on the ext cabs, i think there is about 12 of them per side. I beleive they are the same clips that hold the dash in.
    On the rear doors of an extended cab? The dealer should have them or can get them.
    Post here if you want me to check on them and possibly send some.
    Yes the rear doors of an extended cab. I beleive they are used in the dash as well. I was just looking for the part number as the local parts guy is kind of a doof. If you have time feel free to take a look.
    Give me a year range. They probably not the same on the dash...depends on the year as well.
    It's an 03 ECSB Z71.
    The clips for the swing out doors are 15748479 $0.77 each, 10 per door. The IP bezel clips are 15042047 $4.90 each.
    We have none of them in stock.
    Hmmm they look almost identical. When I get some I will follow up if the are interchangeable.
    Thanks!
