Results 1 to 4 of 4
Thread: rear window leak.
    Dec 2008
    Maryland
    rear window leak.
    Last nite on my way home it started raining and the person in the back was complaining about getting wet. lol. I checked it out and the head liner was wet and it looked like my back window gasket was wet. If my third break light was leaking could that cause this? Im going to check it out today in the daylight. Any help would be greatly appreciated.
    blanco,tx
    Probably is your TBL unless you've had your back glass replaced.
    Dec 2008
    Maryland
    na the glass is factory. Ive had my third brake light out before. mabe I messed the seal up?
    It is definatley the TBL. I made the dealer fix mine. Good luck!
