on my moms 03 nali the cluster isnt working.where it tells you trips,mpg,and all the options. it just keeps asking u to choose a language,but nothing works.hard to explain. every now and then it works right.
may need a update programming, if that does not work need replacing.
5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, TrailBlazer converter. SOLD
_____________________________________
2006 2500HD 6.0L Crew Cab 2WD
if you have less than 70,000 miles you might check into your local dealership and see if they will cover it under the special policy for clusters.
MY GARAGE - http://www.ls1truck.com/forums/my-ga...ns-garage.html
2004 GMC Sierra - RCSB
it has about 120,000 on it. i thought only the gauges and all that was what was wrong with that year.
03-05 now...only for sticking needles 70K miles and less.
The problem you have is likely in the switches or the column harness that comes with the SIR coil.
how do i fix it
Sorry bro, that's something I need to see in person to diagnose.
damn,i hate it.cause most of the time everything goes into french.haha
