Results 1 to 10 of 17
Thread: need help motor options for daily
    GA
    My truck is a 99 silverado nbs 185k on the clock on a 4.3 Ive always wanted to swap in a v8. But the truck has what i assume are many electrical problems. None of my gauges work. fuel pumps only last about 4 months. The truck shifts right sometimes and then other times its weak or will just tach up and have to let off to shift. The motor and tranny are fine its something electronically thats up.
    Its been nothing but a headache for 2 years. I dont want to attempt swapping in a 5.3 and new fuel pump for it to only have more electrical problems. And run like crap after spending loads of money.
    I need opinions on what to do with it. ive talked to the bank about finacing a new truck and they want too much since im only 20 and have no credit.
    Im to the point that its even crossed my mind to rip everything out and run an old school carb motor. Someone give me some options here. This is my only vehicle and i need it for work.
    04 5.3
    224/224 .566 .566 114
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    Plainfield, IL
    None of the options you want to hear are going to work with it as your only vehicle. Any kind of major mod takes time. I'd try to just get the electronic issues fixed for now. Worry about making it "all that you want" when you're older and can afford another vehicle.
    GA
    Its not even that anymore. Im not trying to do anything wild or even somewhat mild. I just need something that works.
    04 5.3
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    southside VA
    I would get everything right then do the v8 swap but I wouldn't do a old school setup since its you're daily
    GA
    Thats the thing for the past 2 years ive traced wires and harness. Cant find anything broken frayed or cut. Have no idea where the problem is. Cant afford to pay someone to do it since they charge a arm and a leg
    04 5.3
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    Have you replaced any parts? If so and the problem is still there you could have afforded to pay someone to diagnose it....provided you have the proper person.
    GA
    no one local know about anything newer than a carbed motor it seems lol small town. only option would be a dealer. and ive replaced parts but havent spent hardly anything like i would to have the full electrical re wired
    04 5.3
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    I doubt it needs rewired.
    Round Rock, TX
    the truck was bagged at one time right? So what wires were cut/lengthened and what was relocated for the bag setup... I would start there with the obvious.
    GA
    Nothing with the wiring was touched. Also all these problems started before it was bagged. When it was stock.
    04 5.3
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
