Results 1 to 10 of 16
Thread: what could have caused this?
    slidelll
    http://www.streetsourcemag.com/ViewOwnerProfile.aspx?ProfileID=39253[/url]
    http://s133.photobucket.com/albums/q...sizerst/truck/
    College Station, TX
    whoah thats nuts...
    slidelll
    i like the part when you see the guy running off when it starts back up again
    Quote Originally Posted by FullsizeRST View Post
    +1
    Make sure not to have your volume on. No audio needed.
    WHOA! Thats nuts man! Seriously tho...how does something like that happen?
    hot & windy
    wow... that's all i can say
    00 FRC - just top end, exhaust, and a hot-air intake
    99 Sierra - 5.3 / 5spd
    ↓ click the pic for the build ↓
    slidelll
    i dunno but its crazy thats for sure...
    check this one out its long but cool as heck
    YouTube - Oil Driller Breaches Salt Mine Under Louisana Lake
    The drain plug the truck drove by was obviously pushed out by a pressure change. If you notice the surroundings, the topography seems to be very steep--as in it is near a hill or small mountain. The drain, which is obviously rather large due to collecting the massive amounts of rain water as it all runs off the large hill or mountain, was obviously maxed out. When static pressures get so large within a drain as such, any sort of seismic movement jarring the drain pipe can cause catastrophic damage. The initial surge was the immediate release of pressure. Once it had subsided, it created a negative pressure effect (like a vacuum), allowing the excess water run off to drain back in. Once the negative pressures zeroed out, then positive static pressures once again forced the spewing of water from the orifice. Think of it this way: When pouring liquid out of a tank or container--and you don't have a vent or a pressure release valve--you can only pour out a certain amount until the static pressure gets high enough to suck in air to fill the void created by emptying the liquid. Thank Newton for figuring that out for us. Kinda like pouring gas out of a gas can...some comes out, then it gurgles, then it flows out again, then gurgles, etc.
    Water (liquid) is the most powerful force in nature.
    San Marcos Texas
    I would bet rain (something we rarely see) caused this!
    Quote Originally Posted by GMCwantsLS1 View Post
    What is this "rain" substance you speak of?
