Results 1 to 10 of 19
Thread: Lq4 or Lq9??
    Feb 2008
    Arizona
    Lq4 or Lq9??
    hey buddies, I have a question for you guys.. how can you tell if a 6.0L engine is a Lq4 or Lq9 by just looking at them from the outside? the casting on the Lq4's heads are 317's right? might be wrong.. that's why I'm asking.. in case I'm right, what does the Lq9's heads say? or is the another way to tell??
    thanks!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    wichita falls, tx
    both have 317 heads
    Intro Radicalli's
    Feb 2008
    Arizona
    so, if they both have those heads, is there another way to tell one from the other?
    wichita falls, tx
    take the heads off....thats the only way i know...did the truck come with that motor?...if so check the vin
    Intro Radicalli's
    Round Rock, TX
    only way to really tell is to pull the heads like mentioned above or use a scope to look through the spark plug hole at the top of the piston...If its flat its a LQ9, dished its a LQ4.
    Quote Originally Posted by DBRODS View Post
    +1
    Slimsilverado Guest
    +2
    Oct 2008
    Houston, TX
    So what's better the dished or the flat
    Airaid, alpine double din,
    Round Rock, TX
    flat is better for NA builds and Dished is better for FI applications.
    College Station, TX
    lq4's have lower compression which is better for fi like a turbo.
    lq9 has higher compression but also comes with like 20 more hp stock.
