Alright so my truck has that brake boost deal (pic below)...i guess its a vacuum booster...my understanding is that it helps the brakes when you arent making enough vacuum right? So keep with me here....if you are building boost while trying to stall up on the line i have heard that the boost will actually lift up on the brakes for you a little, which is why some are going to hydroboost brake setup. Well what if at the track i simply unplug that vac line and cap it off so i dont have a boost least and just let the vac deal work the brakes....i know my brakes will still be okay cause right now i have been driving around without the vac line on for a few days (without knowing)
thoughts on this??
