well ,my 03 doesnt have those sqare rails,or my o7 motor,but the funny thing is i have a wrecked z71 sub,and it does have those rails.the sub is a 6.0.Im not sure the rails help identify it tho.If you look on the block itll tell you if its a 6.0 and the year.
